We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Panasonic Th42pa30 Hd signals
Discussion in 'Panasonic TVs Forum' started by xavidvd, Oct 25, 2005.
  1. xavidvd
    xavidvd
    Interested in the launching of the new console XBOX 360, I have a question :
    My TV Panasonic Th42pa30 (Viera) accept signals 720p or 1080i ?
    I'm sorry, but i have not found any information ..............
    thanks !!!
  2. xavidvd
    xavidvd
    I have spoken with Support Client and answer: this TV it's not compatible with 720p/1080i !!!
  3. Si133
    Si133
    But wasn’t this TV advertised as HD at the time?
    I bought one, with the view that HD won’t really have a foothold for a few years, so it didn’t matter if it was or wasn’t, but now I’m interested in the XBOX HD.
    Can it be converted or fed an HD signal via scart?
    Anyone?
  4. scarty16
    scarty16
    Jul 1, 2003
    1,722
    +499
  5. AidenL
    AidenL
    Nov 16, 2005
    4,779
    Ireland
    +1,451
    I have one of these as well - so will this particular model not even accept a HD signal via Component as a last resort? :(
  6. scarty16
    scarty16
    Jul 1, 2003
    1,722
    +499
    scart = no HD, SD only
    Component = look in the manual, you need 720p and 1080i @ 50hz & 60hz
  7. IAmATeaf
    IAmATeaf
    Jan 3, 2005
    766
    46
    South of the Watford Gap
    +150
    When I got my PE50, diff model I know that it would accept a HD feed via component but would obviously downscale the picture, hope I wasn't fed horse doo-doo.
  8. scarty16
    scarty16
    Jul 1, 2003
    1,722
    +499
    HD can be any of the following for UK purposes (based on HD ready specs)
    720p @ 50hz
    1080i @ 50hz
    720p @ 60hz
    1080i @ 60hz
    Therefore if you say your TV is "HD compatible" via component (notice I don't say HD ReadY) it should be able to handle all of the above.
    From memory I don't believe the 30 and 50 model do, but if somebody knows better please correct me.
  9. AidenL
    AidenL
    Nov 16, 2005
    4,779
    Ireland
    +1,451
    Drat, new telly for me then.....the current one is only 18 months old.....:eek:
  10. Orwella
    Orwella
    Oct 10, 2004
    750
    28
    Romford
    +31
    Before buying a new tv, try the XBOX360 out using component 480p. As your screen only has 480 vertical lines, this will look just as good as if it accepted 720p or 1080i and downscaled internally.
    Trust me, 480p can look very good and your screen will accept it.
  11. AidenL
    AidenL
    Nov 16, 2005
    4,779
    Ireland
    +1,451
    Looking in the manual it says this:
    Scanning Format - 525 (480) / 60i-60p, 625 (575) / 50i-50p
    Is this a lost cause for HD then? :confused:
  12. scarty16
    scarty16
    Jul 1, 2003
    1,722
    +499
    looks like it is a lost cause, and look on the bright side, a new Plasma is required!!
