Panasonic th42pa20
Discussion in 'Plasma TVs' started by dali1020, Jul 11, 2004.
  1. dali1020
    dali1020
    Jun 26, 2004
    285
    Reading
    +3
    Anyone got this screen? "This may be the one for me !" would like any info (pic quailty, connections, wall mounting pics etc :thumbsup: ) cheers
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    This screen is now discontinued. The replacement is the TH-42PE30 or Viera screen. Search for either of those two phrases, although at the moment those two phrases already dominate the first two pages of the plasma forum so search may not be necessary!!!
  3. kace
    kace
    Great screen if you can get hold of it.
    I've had mine for 3 months now. PQ is stunning, very crisp - its like watching a CRT its so clear.
    I have my cable box hooked up to it and i'm impressed. Well worth the bucks. :D
  4. Elvis
    Elvis
    It also gets my recommendation, if you can find one. The new Viera's are based on the same display so they should be equally competent.
  5. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    if you go for one, try and get a 2004 model. There was a power supply problem on early models. Top picture. Comet still have some.
