Panasonic TH42PA20 - faulty transistor?
S
sonic
Hi, I wonder if anyone can help.
I am considering buying the Panasonic TH42PA20, however, after reading the following reviews I'm not so sure:
http://www.dealtime.co.uk/xPR-Panasonic_TH_42PA20
In brief, they indicate that a faulty transistor causes the Panasonic to switch itself off after a few months use. Has anyone encountered this problem? Or has Panasonic now rectified it?
sonic
This problem only appeared to affect the monitor only PW6 screen not the PA20. I had never seen any comments regarding the PA20 having this problem.
It only affects the early batch (last August/September) and is very simple to fix. Panasonic have definitely fixed it in the PW6, (screen only), models.
Steve.
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
