Panasonic TH37PX60B vs Samsung LE37S73BD?
Discussion in 'Panasonic TVs Forum' started by pincher99, Dec 29, 2006.
  1. pincher99
    pincher99
    May 28, 2006
    I'll be buying one or the other tomorrow (probably) - they are both £799 in Currys.
    The Panny is Plasma and the Sammy is LCD - I'm no expert and probably won't really be able to tell the difference between the 2, so which do I go for? I've heard so many conflicting reports about Plasma over LCD and vice versa that I'm confused.
    It will be used with a bog-standard DVD player, Sky+ and a Wii - the Panny has one more Scart but the Sammy has a higher pixel count.
    Additionally, is there a better way to connect the Sky+ other than scart?
    Thanks in advance for any pointers you can give :smashin:
  2. pincher99
    pincher99
    May 28, 2006
    Can anyone offer an answer to the better TV of the two?
    Basically, it comes down to Plasma or LCD on a 37" screen - what do you guys recomend?
  3. matty555
    matty555
    May 20, 2006
    226
    Nottingham
    +9
    I don't know much about the Sammy but I have a 42PX and its riddled with snakes...before you part with cash have you read the Colour Problems thread...? Might be worth a look.
