Panasonic TH37PW7 , is this a good set or should i get something different
Discussion in 'Plasma TVs' started by grenfellion, May 25, 2005.
  1. grenfellion
    grenfellion
    I am a plasma virgin so any good advice would be helpful , I dont have bags full to spend but i could stretch to the hitachi Hitachi 42PD4200 , but am i going to notice a vast difference apart from the 5" of course.
    Also Is this one any good as the independant electrical place has one and he is only about 3 doors down ,so instant delivery :)
    I currently have a Sony AV-300 system to run with it
  2. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    The TH37PW7 is highly rated and you won't be disappointed by it. Get a demo to be sure. It might also be worth checking prices with some of the advertisers on the forum you might find that you are suddenly able to afford a TH42PWD7.
  3. grenfellion
    grenfellion
    k cheers
    also found this for £1199 Samsung - PS42V4SX and not sure with it being samsung whether its gonna same build as those *spits* tiny ones
  4. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Can't help with the Samsung but from the spec sheet on their web site it is a different sort of beast to the Panasonic as it is a TV rather than a panel. What source equipment do you already have or are thinking of getting?
  5. grenfellion
    grenfellion
    Only thing I have at the minute is my old 28" widescreen tv ,sky and my sony av-300 home cinema/amp/dvd player combo.
    Like I said i am a plasma virgin so just wanting an opinion from people who have and use em rather than some salesman in a shop filling me full of garbage :)
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    OK so you have sound and DVD from SOny unit, you will need a tuner to watch TV, Sky, cable or FV box will be a digital tuner a VCR or DVDR an analogue tuner, so with sony kit and Tuner all you need is a disply and a 37 or 42 PWD7 will be ideal 42" PWD7 with mount (table or floor) is £1370 delivered from AV-sales (for £50 get a dual slot input board fromt them too) get a demo but if you like the panny thats a hell of a deal for £1400
  7. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Given that you have got Sky is there any point on spending money on a TV tuner? I would route all the cash towards getting the best display panel (and decent cables, and a converter).
  8. grenfellion
    grenfellion
    I currently only watch tv through sky anyway , I dont have an outside aerial anyway
  9. grenfellion
    grenfellion
    is the th-42pwd6 an older model of the th-42pwd7
  10. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
  11. grenfellion
    grenfellion
    between the 2 plasmas in my last post ,is there much difference or is the 7 alot better?
    I am going to have a look at some units tonight to have a look at what i like
  12. ukdan
    ukdan
    Feb 16, 2005
    1,124
    swindon
    +84
    Please dont buy that screen, PQ is awful. I have had 2 of them now and both were shocking (and faulty). There s a lot better for the money!
  13. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    There isn't a major difference between the 6 and 7 series though you can't input component via the D-sub port on the 7 which is a downer for some but shouldn't be a problem with your configuration. The 7 is a bit brighter than the 6 but the difference isn't huge.
