Panasonic TH37PW4B Motion Problems
D
daver
Apologies if this has been asked before but looking through the forum I can't see anything definitive on the problem I'm seeing.
I've just purchased a Panasonic TH37PW4B which on the whole I'm very pleased with. I do have one problem though that is starting to drive me a bit crazy.
On fast moving images that move left to right (or right to left) and have well defined outlines I am suffering from what I can only describe as "image lag". The object appears to not move smoothly across the screen but "jitters".
I've tried various contrast/brightness settings in an effort to stop this. I've also tried connecting equipment via the RGB connections and S-Video and nothing seems to make any difference.
I spoke to Panasonic technical support who told me this was normal with plasmas.
Does anyone else with the Panny see this or have I got a duff display?
I have the 42" Panny and have no jitters or any problem whatso-ever
sounds Like you have got a duff model
S
strackal
thats a similar problem i have with my 42" LG
when watching football there seems to be a image lag or shadow.
dont know if its to do with the cheap scart I have at moment tho.
ITS SO ANNOYING THO!
makes your eyes hurt to..
MarkE19
I've not noticed this either, but then again I am as blind as a bat:D (that is my excuse for getting a BIG TV :clown: )
Mark.
DaveCheltenham
daver - A couple of things.
I assume you are using the Panasonic connection board as initially I used a progressive scan unit on my 42 with severe similar (and many other) problems. I cured this by going for the Panasonic connection board. Interestingly, using a multimedia computer (850MHz) in the PC Input gives the same effect to some degree.
The other is the source material. I have noticed this on relatively low bit rate DVD's and DTT/DST. Good ones like "The Godfather Box Set" are almost free from this effect.
Hope this info may be helpful.
N
NIIK_TT
I was in Comet yesterday and noticed image lag on the LG model.
