Panasonic TH37PW4
Discussion in 'Panasonic TVs Forum' started by thedude, Oct 18, 2004.
  1. thedude
    thedude
    Oct 18, 2004
    9,977
    Swindon
    +2,019
    Hey fellas im looking for some advice, ive got the above plasma along with the tuner box. I have or think i have read reports oin this screening being HDTV ready!! im not sure if thats true but the homecinemachoice website says that the 42 is. If this is the case however does anyone know if i can get a dvi input card or will my tuner box surfice as it has component with prog scan! also for hdtv doesnt it need to be able to cope with 1024/724?
    thanks for ur help in advance
    Neil
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    PW4 is an SD plasma of 852x480 resolution that will down scale anything over that resolution... PAL DVD's get down scaled etc as does PAL TV I cant remember if the Tuner, 400 model that connects via RGBHV RCA cable, will accept a higher res signal via component. My advice to make the most of the panel is ditch the panny tuner and and Get a DVDO IScan HD scaler circa £1000........ and use that as video switch (you lose scart and analogue tuner but) gain much higher quality video processing and other options. There is no DVi input available for the PW4 so the DVi on the Iscan would not be used ( but great for when you upgrade to a newer HN panels Still circa £3k and only 42"/43 and 50+" sizes.....) LCD may offer the best upgrade route... something like this http://www.sharp.co.uk/aquos_tv/range/products/product.asp?id=26
    Which is higher resolution and HD compaytible and includes Digital video connection.
  3. thedude
    thedude
    Oct 18, 2004
    9,977
    Swindon
    +2,019
    ok thanks for the advice im looking towards getting the pioneer 43" anyways as that has HDMi inputs two RGB scarts and compnent video i imagine at 3200 its gunna be the best value for money out there with a decent picture.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Or you could go for a Panny PHD6.... Hi DEf plasma???? Similar money or Progressive AV were doing the Fujitsu 50XHA for £3.5k which is a huge jump.......... PQ and size wise.....
    PErsonally i would suggest an in home demo of an Iscan HD on your plasma which is a good idea anyway if looking to maximise PQ from any plasma and compare it to a Pio
  5. thedude
    thedude
    Oct 18, 2004
    9,977
    Swindon
    +2,019
    been reading the reviews of the fujis but they dont ever seem to be coming out that great any more. is it because some of the others are getting better or are they doing a sony by just trying to sell themselves on there name??
    I think 50" is a lil to big i mean i only sit 12 feet away it wud be an eye strain and a half that.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Dunno but new models are due soon ish...... PRices have fallen to competitive levels, Fujitsu were one of the very first plasmas and have always comanded a premium price.. 12 50" perhaps a bit big.......... I still say get a demo of an Iscan HD
  7. thedude
    thedude
    Oct 18, 2004
    9,977
    Swindon
    +2,019
    i might get a demo of that iscan thinging looks quite good not sure a grands worth of good when thats a third the price of the pioneer.
    and on a side subject does anyone know how to activate the service menu using my tuner box? etc..
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    not on PW4 mate...... phone panny if you fancy a half hour of dodgy hold music....
  9. thedude
    thedude
    Oct 18, 2004
    9,977
    Swindon
    +2,019
    hey there music is prolly the best hold music in the world i always seem to want to strip or something its so porn like :oops: far too much info
