Panasonic TH37PV500PED - Anybody know....
Discussion in 'General TV Discussions Forum' started by salfordred, Aug 17, 2005.
Tags:
  1. salfordred
    salfordred
    Feb 2, 2005
    89
    .... Is this set going to work well with the Sky HD, and will it play XBOX and XBOX 360 well ?
    Any other comments on this set will be very much appreciated as I am within 24 hours of buying this set.
  2. emporer
    emporer
    Mar 10, 2005
    8,077
    +1,626
    excellent set, will work pukka with both sky hd and xbox360. One of the best plasmas around, my 42pv500 is my pride and joy, hi def is just stunning
  3. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,259
    +763
    The PV500 series are fully "HD Ready" - and so should work with box XBox 360 and Sky HD. They have both HDMI and Analogue HD inputs, and cope with 1080i and 720p signals at 50 and 60Hz. The only potential caveat is that some early HDMI screens and some HDMI sources aren't brilliantly compatible in the US - though hopefully this will have been ironed out by the time Sky launches.
    The whole range seem to deliver great looking HD pictures - some of the best plasmas I've seen. Most people seem happy (though there is an ongoing "stuck" pixel issue documented elsewhere on hear that one user has suffered from)
  4. SimonMallion
    SimonMallion
    Feb 15, 2005
    78
    Also bear in mind that the PV500 only has one HDMI socket.
  5. kingsize
    kingsize
    Jul 16, 2004
    1,038
    +49
    and the hitach has 2 hd inputs - no switchers needed
    xbox 360 -DVI
    sky - HDMI
    DVD - Component
  6. salfordred
    salfordred
    Feb 2, 2005
    89
    Which Hitachi would this be ?
  7. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +122
    And which Xbox 360? The one coming in November is NOT going to have ANY digital video output - only analog via VGA or Component for progressive, and SCART for interlaced, as well as S-Video AV.
    So whichever set you buy (inc the Hitachi 7200), you'd better save some money for a separate component switcher unit, or buy a display with 2 component inputs at least.
    Better still, buy an AV Processor/Amp to do the audio and video switching.
  8. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,259
    +763
    Ah - is the Hitachi DVI input a DVI-D or a DVI-I one? Don't forget that DVI-I is analogue VGA compatible with a simple cable, so would be compatible with the analogue output of an XBox 360. Of course if the Hitachi in question is DVI-D only (i.e. no analogue inputs on its DVI input) - then the DVI input wouldn't be any good for XBox 360 connection.
  9. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,259
    +763
    Is the DVI input an analogue compatible DVI-I type (i.e. analogue AND digital compatible) - or DVI-D (digital only). If the latter then it won't work with the XBox 360 which is analogue only.
