Panasonic TH37PV500 - AV Connections & DVB?
Discussion in 'Panasonic TVs Forum' started by Carloto, Oct 24, 2005.
  1. Carloto
    Carloto
    Hoping someone can help me on these?
    1. AV SCART Connections
    Have bought a Panny TH-37PV500 and I have setup as follows:
    AV1 SCART IN - from Sky Receiver
    AV2 SCART IN - from Video Recorder
    AV3 (S-VHS at front) - Not Used
    AV4 SCART IN - from DVD Player
    Picure is very dodgey on AV2 for the Video. I have looked at the manual and I am wondering if I have misunderstood something! :rolleyes:
    Is AV2 only supposed to be used to connect to another unit in output from the Plasma to say a DVD/HDD recorder or VHS recorder? Therefore thats why the pciture is rubbish? Q-Link is mentioned and AV2 is some kind of data link. Can anyone explain this is in simple english please?
    2nd Problem - DVB Freeview
    I cannot pick up any signal at all on the DVB unit. In Analogue I can get some channels but very fuzzy. Can anyone help me out or suggest some simple resolutions? :lease:
    Thanks a lot.
  2. chrisw
    chrisw
    May 20, 2004
    2,419
    83
    Maidenhead
    +263
    Firstly is the scart cable you're using fully wired? When you say dodgy, what do you mean?
    2nd problem - do you normally get a decent picture on your old TV (assuming you have one)?
  3. Carloto
    Carloto
    Sorry I dont know what a fully wired scart actually means? Picture is kinda pale blue and white not quite black and white.
    DVB/Analogue Tune - No didn't get a great picture before so i guess I need to recheck all Coax and AERIAL maybe needs repositioning. Have heard that sometime you need to change your aerial to a wideband aerial?
