Panasonic TH37PE50B Wall Mounted - Thanks to all who helped
Discussion in 'Home Cinema Buying & Building' started by DJT75, Sep 6, 2005.
  1. DJT75
    DJT75
    May 6, 2005
    9,422
    +2,502
    Just a quicky to say thanks to all that assisted my decision over the last few months. A few pics attached of my new Panny 37PE50 for you to see. Very happy with my purchase + saved a bunch of cash. (Through EBUYER £999)
    Only have a DVD & Sky going in on scarts - that's all i need (have learned cheap scarts are a no-no too)
    The old 25" Sony CRT has been retired to the bedroom.....
    Cables will be going in a simple white cabl box to cover the 8-9 inches above the chair.
    Cheers All!
  2. chrisw
    chrisw
    May 20, 2004
    2,389
    83
    Maidenhead
    +271
    Looks good - have much trouble getting it on the wall?
    What is your viewing distance? Decided what to do with the wires yet?
  3. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    I have to say that I don't think that white chair is in the ideal viewing position... :)
  4. chrisw
    chrisw
    May 20, 2004
    2,389
    83
    Maidenhead
    +271
    Unless you're an owl!
  5. DJT75
    DJT75
    May 6, 2005
    9,422
    +2,502
    No trouble getting it on the wall, 2 man job, mind your fingers!! For a 30kg machine + the frame there's only 8x M6 8mm screws holding it up - surprizingly easy to mount.
    Viewing distance must be about 10-11ft - you can see from the 1st picture..
    The white chair stays there - the whole reason of wall mounting was so I could move that over to that side of the room & make more use of my dining suite, which has spent the last 3 years pushed up against a wall. It also hides the cables very nicely - just need to add a white plastic cable box vertically down from the middle of the lower panel.. The SKY Box/ DVD etc are to the right of the chair in the corner of the room.
    Picture suddenly went terrible last night during Spiderman 2 on Sky - changed the cheap 3m scart for a better quality 1.5m scart (bit of a stretch) & it went back to
    normal again.
    The only thing I can't work out since installing this & moving the CRT upstairs: My Sky mouse/eye thing upstairs nolonger changes Sky channel from upstairs - it receives the feed OK & the remore control is working fine but won't let me select the Sky menu or change channel?? Must be a faulting cable or eye I suppose...
  6. chrisw
    chrisw
    May 20, 2004
    2,389
    83
    Maidenhead
    +271
    Dj - just got mine this morning - but seems to be wihtout the wall bracket - was it in a seperate box? I was so excited when he turned up it took me an hour to realise there was no wall bracket... :(
