Panasonic TH37PE50 - how deep?
Discussion in 'Panasonic TVs Forum' started by sirp2000, Mar 21, 2006.
  1. sirp2000
    sirp2000
    Mar 20, 2006
    13
    I am seriously thinking of buying one of these. Does anyone have theirs attached to the wall? If so, can you tell me the distance from the wall to the screen, ie how much does it stick out? Cheers
  2. sirp2000
    sirp2000
    Mar 20, 2006
    13
    Bounce - anyone? The TV is 10cm deep, but how deep is the bracket? Cheers
  3. abooker
    abooker
    I'm in the process of finally putting mine on the wall, and when I opened the wall bracket box the depth of it was similar to the TV to be honest, perhaps a couple of cm less ...
  4. Mark V
    Mark V
    My 37PE50 is mounted using a great wall bracket from ebay that costs £55. The front face of the frame of the TV is 129mm from the wall.
  5. sirp2000
    sirp2000
    Mar 20, 2006
    13
    Thanks, Mark V, very helpful. Does your frame have a name/number as I might try and get one as it sounds like it may be a lot less deep than the one provided with the TV? Cheers
  6. Mark V
    Mark V
