Panasonic TH37PE50 Cable Question
Discussion in 'Panasonic TVs Forum' started by BettySwollocks, Jul 24, 2005.
  1. BettySwollocks
    BettySwollocks
    I've been reading this forum for a while now and have recently purchased a Panasonic TH37PE50 mainly due to budget constraints. Its due on Monday and a friend has offered to mount it on the wall. What i need to know is what cables should I have buried? All I want to use it for is Sky and a DVD player.
    Thanks in anticipation. :)
  2. NWhiteley
    NWhiteley
    May 29, 2005
    2,038
    Westhoughton
    +96
    i think most people will allow for scart(rgb), component, rf and of course a power lead. im no expert so i have my flame suit on :smashin:
  3. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    I'd bury 2 sets of RGB enabled scarts, I set of components and a set of phono's for the component.If you're on a budget and need long runs, Maplins do reasonable cables try Maplins, they do 5m/10m Nikkei scarts and components for around £20-25 a set.
    Even if you're not gonna use the components and/or other scart cable at the mo it might be a mistake not to bury them for future use.
