Panasonic TH37PE30B questions
Discussion in 'Panasonic TVs Forum' started by Jack_Rudlin, Sep 6, 2004.
  1. Jack_Rudlin
    Jack_Rudlin
    Are these better that the PW6 ? Anyone any experiences?
    I'm looking for something around the 2k mark. Preferably something with composite in (does that mean hdtv in?)
    Jack
  2. cinesom
    cinesom
    Aug 30, 2004
    30
    Hi Jack,
    The Th37PE30B is a Plasma TV (i.e. has a tuner built in, 3 SCARTS, Component Video and other inputs on the front), the PW6 is a Plasma Monitor. No you cant get either for 2k.
    Composite in is not HDTV, for that you will need a Pioneer, but not currently the Panny. Composite is the poorest sort of video signal. Aim for Component, RGB or HDMI
  3. Jack_Rudlin
    Jack_Rudlin
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Hi def capable, it will display an HD image but will down scale it, there is a 42" monitor plasma from Panny that is HD well (1366x768) Pio 43" is same res only true Hi DEF flat panel TV is up coming sharp 45" LCD with tru 1920x1080 res and a monster pricetag!
    For 2K you wont get Hi Def flat panel, only SD choice is Panny PW6/7, NEC?!?!, Hitachi (dont be fooled by staed res of 1024x1024, they are not true Hi res but Alis) Also Fujitsu monitors at just over £2k and 32" and 37" Plasma TV's perhaps the odd 42" but dont touch cheap nasty Techwood, Sky, Goodmans etc (brand-X) 42" units, not worth it IMPO
  5. Jack_Rudlin
    Jack_Rudlin
    hornydragon, thanks for the inf0 - extremely useful
    I'm gonna go the way of the PW6 as avsales are doing the best price around it seems. DO you know, with the RCA component in slot, will the panny except a hi-def signal from the xbox and other sources - albeit, downgraded to fit the lower res.
    thanks
    Jack
