Panasonic TH37PA30 37inch
Discussion in 'Panasonic TVs Forum' started by Jed, Oct 25, 2004.
  1. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Errr hold on.
    Whats this model then.Panasonic TH37PA30 37inch High-Definition Plasma TV with analogue tuner & speakers
    http://dvdworld.co.uk/hardware_body.asp?pf_id=87602
    High deffo but analogue tuner.
    Anything else missing of this.
    Is it more future proof than the PE.
    Jed.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    its a European model and HiDef ready refers to 1080i input and compatibilty with 1080i signal not that it is a HiDef panel.... Dont buy a Europe import unit as the FV in the PE30 really sets it apart from the dross.
