Panasonic Th-50PW5B How do I know if...
Discussion in 'Panasonic TVs Forum' started by delta, May 20, 2003.
  1. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    I know this has been asked before but I have searched and can't find the thread! Q: How do I know if my panel is outputting progressive scan? There is a way into the service menu apparently, which gives that info. Which setting should I use for NTSC or PAL prog.scan? Is it more likely that the panel is already set-up for prog.scan? The picture is so darned good anyway I can't imagine it could be better! But it might be...! Any help appreciated.
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +14
    The picture displayed will be Progessive because the plasma is a progressive device. It will de-interlace an interlaced signal to display it.
    The question is
    Is the picture better if the de-interlacing is done externally & fed progressively to the RCA/BNC inputs (that will accept Prog scan input.) ?
    If you want to see if the panel is accepting a Progessive INPUT
    here is the link to the thread you were looking for I believe.
  3. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    Thank you, you answered my question satisfactorily and also led me to the thread I was looking for! Don't worry, I'll be careful. Thanks again.
