Panasonic TH-50PH9 colour change
Discussion in 'Panasonic TVs Forum' started by UKenGB, Apr 25, 2007.
  1. UKenGB
    UKenGB
    Dec 20, 2005
    130
    London
    +3
    No, not the screen, just the surround/bezel:)
    I ended up with a silver one and would really prefer one with the black/charcoal surround. Is there anyone who can help with this? A panel being stripped for spares, someone wants to change their black one for silver, or even advice on the possibility of spraying it.
    Hope someone can help. Thanks.
  2. ojo
    ojo
    Jun 7, 2006
    85
    +7
    Bezel off, rub down, plastic primer, plastic top coat paint in any colour you want, in that order. I wouldn`t spray it while its still still bolted to the display. Probably to much hassle than it`s worth unless you could easily remove the bezel.
