Panasonic TH-50PH10
Discussion in 'Panasonic TVs Forum' started by AndyWillett, Jul 18, 2015.
  1. AndyWillett
    AndyWillett
    Jul 18, 2015
    3
    Berkshire
    I was hoping if anyone could give me any advice on setting up a skybox to a Panasonic TH-50PH10 Plasma Monitor, It doesn't have SCART or HDMI connections, I have tried a VGA to HDMI adapter from Maplin which didn't work. Would anyone be able to give any advice? Feel free to ask any questions, - Many thanks in advance and will appreciate any input!
    Andy
  2. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,823
    Sector7
    +1,112
    HDMI is an encrypted signal - so not as easy as a simple conversation, have you had a look at a the HDFury options, which allow you to connect to the vga port from a hdmi source, other than that you can buy a Panasonic HDMI blade for your display, which will be compatible with SkyHD.
  3. JayCee
    JayCee
    Jan 20, 2004
    23,989
    Lanarkshire
    +2,614
    I presume you meant an HDMI to VGA adaptor as a SkyHD box does not have a VGA output and as you've already stated your Tv does not have an HDMI input.
    Your Tv possibly has Composite video and audio inputs (3 RCA Phono sockets coloured Yellow, Red & White) so if it does simply connect these inputs to the same coloured outputs on the Sky box and you will get a picture & sound...it won't be HD and it won't be great but it will work.
  4. AndyWillett
    AndyWillett
    Jul 18, 2015
    3
    Berkshire
    Not sure how to check the HDFury options however I went through all the settings I could see and didn't anything too specific regarding HDMI. I appreciate the response but would you be kind enough to direct me to where I could buy a blade? Would this be of use? http://www.ebay.com/itm/Panasonic-42-TH-42PH10UK-TNPA4242-HDMI-Input-Board-Unit-/361237713288
    Yes sorry if that wasn't clear, I fed a vga cable from the TV to a little adapter box from maplin which then fed a hdmi cable to the Skybox however this didn't work.
    I have attached a photo of the connectors that I have that may be phono but I am not too sure? Aslong as I can get a picture I would be happy with that
    I appreciate all replies and advice, thank you for your time
  5. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,823
    Sector7
    +1,112
    Hi Andy,
    No that link you gave is just a pcb from a blade, it's missing the mounting plate.
    Here is the correct HDMI terminal board (Blade) for your display, however they're almost non existing today...
    http://panasonic.net/prodisplays/download/pdf/specsheet/TY_FB10HMD.pdf
    Your only other option is you need to look at the HDfury 2, which is a hdmi - vga device you plug into your display's vga port and it has hdmi in on the other side (more details on the hdfury website), amazon UK link below...
    http://www.amazon.co.uk/HDFury2-Special-Edition-HDMI-Converter/dp/B001Q7TSH2
  6. AndyWillett
    AndyWillett
    Jul 18, 2015
    3
    Berkshire
    Hi Hitman
    Many thanks for the reply! I have found a hdmi blade which is compatable, only thing is I can't find any info on installing it, do you have any idea? I assumed it was just a simple case of removing the plate and then just putting the blade in
    Many thanks
  7. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,823
    Sector7
    +1,112
    yes the cover plate will have 4 screws, usually a new blade will come supplied with it's own if not use them!
    It only goes in one way, so if possible remove the plate and check for the receiving terminal strip that the blade contacts will slot into, push it in firmly and then use the screws to secure it.
  8. RayP
    RayP
    Mar 10, 2003
    3,639
    Cheshire, England
    +1,101
    Andy,
    I may be too late but I have a JS Technology RGB (Scart) to YUV video converter available.
    http://www.js-technology.com/store/product.php?id_product=14
    Together with Scart - component cables and Scart-VGA this provides the highest quality analogue signal to a plasma display. I still have my Panny PH9 display I bought back in 2006.
    The price of an extra HDMI blade was prohibitive a few years ago.
