ozthecoz
Hi all,
I have a Panasonic TH-46PZ81B and i think it may be starting to develop a fault - Could people have a look at the following and give their opinion.
Firstly - the TV is connected to my Onkyo 576 amp by HDMI cable and that in turn is connected by hdmi to a Sky HD box, HTPC and PS3.
I first noticed a problem a few weeks back when i turned on my HTPC and the tv screen kept flashing between the display and a black screen whilst in the top left of the TV the text was alternating between 1080 and Wide - Eventually the screen setled on the Freeview channel - I switched everything off and on again and it did the same thing except settled on the HTPC display and it had intermittent flashing lines going up the left side of the screen and occasionally flashing in other areas of teh screen.
I switched of and on again and all was fine with no problems so i put it down to the hdmi cable poss being on its way out
Anyway - had the problem a couple of other times and other times its been fine - Tonigt i switched on the PS3 and had EXACTLY the same problems described above.
So probably not a hdmi cable prob and either the amp or the tv
Never had this problem when watcing tv via sky hd box either
So - what do people make of it ? TV on its way out or maybe the amp ?
Thanks in advance, Dave
