Panasonic TH-42PZ81B 2009 plasma stuck in standby
Discussion in 'Panasonic TVs Forum' started by cosmic023, Jun 18, 2015.
  1. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hello people,
    Seem to have a problem with this TV. Been working great for about a year. (Bought 2nd hand via a friend @work.)
    Last night i switched it on (from cold, and not standby), and usually the LED will go from a static red to a flashing green and fire up. (Never really bother with standby, to save a few £££ on the electric bill.)
    But it's just a solid red LED, and flashes when receiving commands from the remote? I do get one relay click when hitting the power button if that helps?
    I have noticed many threads elsewhere, about the flashing LED faults will these units from around 2007 to 2009. Also done a search, and didn't find much related to this set.
    Has anyone got any tips / tricks / pointers to start me off in solving this problem?
    Many thanks
    Lee
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Spent a bit more time online searching for faults / solutions. Seems to be a fault with these units, but holding down the power button and holding the +/- volume on the set or holding down the standby button on the remote at the same time triggers the set back into action.
    Now back up & running, and hopefully this will help someone who has this problem.:clap:
    Lee
  3. JayCee
    JayCee
    Jan 20, 2004
    23,993
    Lanarkshire
    +2,615
    With the set switched on from cold and on standby doesn't pressing any number button on the remote OR a single push of the channel up button on the set fire it up?
  4. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hello JayCee,
    Thanks for the reply. As for the set, nothing of the usual tricks would work.
    Touch wood!;) Things are OK again. Seen many problems online with these sets.
    Lee
  5. willowman
    willowman
    Feb 14, 2009
    4
    3
    West Midlands
    I have a TH-42PZ81B which I have had from new. It might sound silly but from what you have described it sounds like the set was actually asleep in standby and the way to wake it up is to press and continue to hold any number key until the LED turns green. It takes several seconds for this to take place. This happened to me when I first got my set and I had to ring the Panasonic dealer for help. I have forgotten what causes this but when you turn on the power the LED stays red but flashes when you press a key.
  6. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Many thanks for the info. I'll keep it in mind, if i ever get that problem again.
    Lee
