Panasonic TH-42PZ70, correct dimensions?
Discussion in 'Panasonic TVs Forum' started by K4S3RYN, Jan 18, 2008.
  1. K4S3RYN
    K4S3RYN
    Aug 28, 2006
    16
    I see this repeatedly reported on websites with two different widths, 1134mm and 1070mm. Can anyone please give me the actual physical width? It makes the difference between fitting in the wallspace or not..
    thanks!
  2. Ivor_Biggern
    Ivor_Biggern
    Nov 6, 2003
    2,314
    +136
    Ive just measured mine.
    The width is 1130mm, the height with the tv sat on top of the ped is 690mm.
  3. km21
    km21
    What are the stand's dimensions ?
    Please answer.
    Thank you.
  4. K4S3RYN
    K4S3RYN
    Aug 28, 2006
    16
    ArgghhH!!!!! Godamnit.. i'll have to redo all the shelving again!! Damnit, might as well go for the 50" then anyway. Thanks for the info :)
