Panasonic TH-42PWD8UK in july?
Discussion in 'Plasma TVs' started by phillfyspoon, Jun 8, 2005.
  1. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,063
    2
    4
    137
    Garstang, Lancs
    +1,597
  3. Enquirer
    Enquirer
    The direct input selection is a major thing for custom installers.Especially if you programme prontos and cheaper universals. It also has the higher colour count of 8.58 billion compared to the 7 series, and although a SD panel it can can display 1080p 24p/24sf, 1080i 50/60, 720p 50/60, 480p/i and 576 p/i and offer support for VGA, SVGA, XGA, SXGA and UXGA resolution.
    nice sd panel from the spec but as always the proof is in the piccy quality.
  4. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    th most iteresting thing i foud is the bezal width aroud the screen. one 8th of an inch! so perfect for wall mounting
  5. Mr.G
    Mr.G
    any pics available?
  6. Xvani
    Xvani
    Standard definition..... BAH
    And I was hoping to see the PWD8 with HD (720p) resolution....
  7. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    it realy looks like this model was designed just for the commercial market, now that they have the new veira's will they treat the PW8 the same as they did the ealier models which were for both markets.
  8. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    I have to agree Xvani. I was sort of expecting the PWD8s to be the same res as the PV500s, which is also 8 Gen panel rather than SD.
    Will it only be the PHD8 that is HD in this range? I wonder what price that will come in at, compared to the PV500? Would it be sensible to expect it to be cheaper, since you won't get the speakers & tuner?
  9. Xvani
    Xvani
    It looks to me that Pannys professional series are generally cheaper then the PA's (for home use)
    The PWD8 DOES indeed have a G8 panel. It is just not HD-ready (resolution too low)
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    There will be an HD version too, it's always later than the SD
  11. xenole
    xenole
    Jan 2, 2005
    114
    How do I tell if the screen is HD from SD? TH-42PWHD8UK instwad of TH-42PWD8UK ?
  12. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    It's exactly the same as it has been the last few generations:
    37PWD - 37" SD
    42PWD - 42" SD
    42PHD - 42" HD
    50PHD - 50" HD
    [just add generation number after the "D" e.g. PWD7, PHD6)
    The linked article is only referring to the launch of the SD panels, the HD ones will come soon enough. Would be nice to see the 37" HD panel in monitor only form...
  13. Gussie
    Gussie
    Oct 19, 2004
    1,236
    48
    +80
    US retailers are already listing the SD product ...
    http://www.electronics-depot.com/panasonic_th-42pwd8uk.html
    Before anyone asks the "UK" designation does not mean UK market - it's just the new suffix Panasonic are using in the US.
    Also the image is still of the old model - no pictures of the new model until next month !
    That price - if it's correct makes one weep - Can't see the SD model being under £1000 here :(
    Gussie :)
  14. dilsher
    dilsher
    Oh wow i can see lots of sales for an SD Panny 8..yeah right ..then again some pple here fancy SD over HD here so why not!!
    Bring on the HD.
