Panasonic TH-42PWD7UY
Discussion in 'Plasma TVs' started by jedblack, Dec 6, 2004.
  1. jedblack
    jedblack
    Hello all,
    I've been researching screen for the past 4 months and it seems that the Panasonic TH-42PWD7UY is my what I shooting for...
    however the "swapable" cards are little confusing
    I basiclly want to connect a DVD player, HDTV time warner signal and an Xbox to the TV...
    will i have to buy an expansion card? or will the supplied inputs be sufficient?
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    It all depends on what your equipment outputs. for dvd component RGB would be best or dvi if you have that. and HDTV? isnt avalible in the UK yet so im guessing your in the US. In which case dvi would be best.
