Panasonic TH-42PWD6
Discussion in 'Panasonic TVs Forum' started by Colonel Burton, Jun 30, 2004.
  1. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Does the above plasma come with a tuner? if not what can you use (don`t have sky if that was something you could use) cheers
  2. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Doesn't come with a tuner but it is an option to have one fitted
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Buy a freeview box (cheaper and better!) or a DVD-recorder!
  4. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    I`m so in a mess now i was all for ordering this plasma then i hear that i`ll need a tunner of some sort then i might need a RGB to VGA converter then spend loads on cables and then might need a scaler whatever that is?? all i want to do is watch tv, connect my vcr and dvd player can anyone please offer any suggestions as to what i would need to do the above and a rough idea of the cost many thanks
  5. VT 4 CCTV
    VT 4 CCTV
    Colonel,
    Have a look in the specials section on AV Forums here, Alastair colly is doing a special on the PW6, and comes with a '''' TV Box''''' solution as well.
    Go on try it, and if your still not sure, click on his link and then click on the plasma screen on his website, and you can see the '''' tv box'''' (Quintro) and see how it all fits together.
    hope this helps
  6. nictry
    nictry
    Apr 28, 2002
    5,649
    Kent
    +644
    Colonel, And I would add to VT's post above that is probably worth giving AVsales a quick call to discuss as they have been great with me this week, I placed my order for the Panny 6 deal and they customised to suit what I needed so I am sure if you tell them what you want to do they will tell you exactly what you need etc. I can't recommend them highly enough!
  7. sargetheboss
    sargetheboss
    Jun 29, 2004
    71
    ALWAYS ON THE PC
    +8
  8. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    So i can do that? what is the PQ like using that method, things might be starting to look up again :) thanks for the help so far guys :thumbsup:
  9. sargetheboss
    sargetheboss
    Jun 29, 2004
    71
    ALWAYS ON THE PC
    +8
    i am not using a vcr to view arial tv .i am running it through a dvd recorder it's sort of the same thing .picture is good through the scart conection. :thumbsup:
  10. BuzzLightyear
    BuzzLightyear
    Jun 3, 2004
    16
    Right Ok - I had a PWD from AVSales, started with a scart card - very soft image with a horizontal "interferance". It has to be said a very sorry state as far as a picture was concerned. Containstly adjustinging brightness and contrast. Then I got a RGB-PLASMA JS Technology and my screen has turned into a dream. I am 100% satisfied with my PQ.
    Next step component card.
    Buzz
  11. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    :eek: did anyone else find this with there panny? i know i`m being a bit of a pain here but i`ve really gotta get this right the first time because if it starts to cost loads of money having spent 2k plus the mr will just kill me then never let me live it down :lesson: cheers again
  12. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    I went straight in with the RGB2VGA convertor and I have to say Sky + picture has FAR beaten my expectations! I also got the component card for DVD and that is just STUNNING!
    Get the component board as your free one and spend the extra £115 or so on the convertor and you will not be dissapointed :)
  13. technovorgin
    technovorgin
    Jun 16, 2004
    226
    Leeds/Wakefield border
    im ordering the deal off av sales next week im putting a dvd and normal sky on it through quintro box do i need anything else?
    sorry im a newbie and if you read my posts will realise ive had a bad time with a philips 9945 so have to get it right this time
  14. sargetheboss
    sargetheboss
    Jun 29, 2004
    71
    ALWAYS ON THE PC
    +8
    i got the offer you are talking about.No you don't need anything else it comes with all you need .I am well pleased with the picture from the quintro to scart.I am running sky /dvd recorder/and xbox through it and all pictures are :smashin: Are you going for the wall bracket or stand because i went for the wall bracket and they are quite easy to fit. :thumbsup: looks better i think on the wall.
  15. nictry
    nictry
    Apr 28, 2002
    5,649
    Kent
    +644
    Same as Sarge, got mine up on the wal last night and it is A1 through the Quintro etc. That deal with AVSales seems to be the best around as well so go for it!
  16. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Thanks guys for the replies much appreciated, i`m now 99% sure i will be going for the panny deal from av-sales just gotta make the mrs see sense that it will be better wall mounted then on a stand :)
  17. technovorgin
    technovorgin
    Jun 16, 2004
    226
    i am but need to see one first cos i sit only 7 - 8 foot away so it has to be right :eek:
    p.s. what is a scaler and do i need one?
    and do i need to go rgb to vga and can i do this from quintro box
    and do the instructions tell you about 'running' in for the first 100 hours or so because ive seen it mentioned a few times on this site :confused:
