Panasonic TH-42PWD6 Setup
Discussion in 'Plasma TVs' started by hitman126, Mar 26, 2005.
  1. hitman126
    hitman126
    All,
    Any assistance on this would be most appreciated and my apologies if I am only raising here an issue that's probably been addressed before.
    I purchased my Panny TH-42PWD6BX from Richer Sounds a couple of days ago and am still in the process of setting it up with the right components. In addition to the plasma, I purchased a Panny scart board from RS for a whopping £149.95 (how a device as small as that can cost that much, simply astounds me). I have a DVD Recorder, DVD Player, Telewest Digital Cable Box and a VCR to hook up to the TH-42PWD6BX, question is, what will be the best setup in order to obtain the best picture quality?
    At the moment, I have managed to connect three of the above devices via a Hitachi scart adaptor, but I am not particularly impressed by the picture quality. Judging by what I have seen elsewhere on the TH-42PWD6BX, picture quality should be a great deal better. Any suggestions fellas??
    Reggie.
    PS: By the way, I am considering swapping the Hitachi Scart Adaptor for a Vivanco AV Control Switch available from Dixons, if that helps.
  2. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    2,336
    Middle Earth
    +130
  3. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    2,336
    Middle Earth
    +130
    Also remember you can use the PC computer VGA type input as another RGB input, so in effect you have two inputs if you can get hold of a scart RGB to VGA RGB type connector.
