Panasonic TH-42PWD6 remote codes
Discussion in 'Panasonic TVs Forum' started by chr15w, Nov 18, 2004.
  1. chr15w
    chr15w
    Can anyone help with oneforall code(s) available for the Panasonic TH-42PWD6 Plasma screen. Specifically I wondered if there were codes to select a particular AV channel, rather than just cycling through PC,AV1,AV2 etc round in a loop.
    I have a oneforall Mosaic remote.
    Thanks.
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    The PW6 does not have discrete codes for the inputs...you can find codes for power on & off plus a few others over on www.remotecentral.com
    Cheers, Lee
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You have to make up a macro, send it 'PC....input.....input' to get AV2 for instance. Works for me.
  4. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    On my PW5 I can switch direct to PC/VGA (learn't from remote) and to AV (Composite/s-video) the code for which I found on Remote Central. For Component I have to switch to PC/VGA and then "press" input twice.
    Rob.
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There are actually discrete codes for the PW5, you don't need to do this. Just that they don't work on 6 or 7, logically cos it has 3 inputs + PC instead of only 2.
  6. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    Discrete codes for component??? Can't say I've looked since I got the PW5 2 years ago....
    Just been over to Remote Central and found the HEX code for this - great :) Thanks for the pointer :clap:
