Panasonic TH-42PWD6 Question
B
bobbles
sorry if this is a daft question regarding connecting sky+
which would give a better picture
rgb converted to component to the component input board
or
rgb converted to VGA to the standard VGA inut ?
CARLOS
I`ve tried both and thought the VGA option was definately better !
The only downside is that you lose colour adjustment.
rscott4563
Have a look at this thread it may help, same question really..
Ryan :thumbsup:
symanski
RGB connected to the VGA input is still the best. RGB converted to component, with the right converter, is slighty softer. This can be an advantage as it does help smooth out some of the encoding noise from Sky giving a cine--matic* effect, but still sharp enough for all the detail.
All the best,
Dr John Sim.
*Edited because of some pop-up virus interrupting my text!
B
bobbles
Many thanks
Judging by your sig I will be buying a converter from you very soon
phfjones
Thank you for these answers, I needed to know this!
One thing I am not clear on, though
Do I need to convert the Scart RGB output on Sky plus to VGA using a convertor, or would a cable with RGB Scart on end and 15pin VGA on the other be sufficient?
Paul
D
diabolik
Ive got the same question. I just got a SCART - 15 pin male RGB from keene electronics (wired RGsB - don't know what the s means???) and it doesn't work. I thought it would,
Anyone know why not??
Dutch
Paul,
To get the best picture quality from Sky you need to use RGB Scart into one of Dr John's RGB-VGA converters. You won't regret it! ;)
diabolik,
I think RGsB means sync on green, whereas you need seperate sync for Sky signals. Hope this helps.
Steve
D
diabolik
Thanks, whos doctor John and where do I get one of these converters.
phfjones
Thanks Steve,
I'll order the convertor today.
Similar threads
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
