Panasonic TH-42PWD6 How much better than Viera.
Discussion in 'Panasonic TVs Forum' started by Jed, Oct 31, 2004.
  1. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Still pondering. Although extremely close to going for the Viera 37"
    This PW6 though. Is it better than the Viera ??
    In what way.??
    What will i need.
    I use Cable instead of sky.
    I have a all in one Pioneer for DVD.
    Which boards will i need for it to be perfect for me.
    The sound looks pretty lacking against the Viera and with me not having to go through a amp is this a big minus.
    I am deffo off the LCD trail though. :D
    Jed.
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    They both use the same panel
  3. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    The Viera is an all-in-one plasma TV, the PW6 is a display-only panel. They both use the same plasma panel for the pictures. If you're looking for a simple TV replacement, then buy a Viera.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    What does pioneer allin one output? If component then i suggest the dual slot board Compnent/RGBHV and S-video/Composite board an the JS RGB>VGA (assuming cable outputs RGB......... You could of course go for the 37" PW7
