Panasonic TH-42PW7B Plasma Owners
Discussion in 'Panasonic TVs Forum' started by thfccambs, Nov 12, 2004.
  1. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Could a Panasonic TH-42PW7B Plasma please give me a little help?I can't find my manuel at the moment(decorating) but would like to change my setting from 50Hz to 60Hz if possible?
    Could someone please post how to do this if it's possible?
    cheers
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Panny website for the manual?
    (failing that being that the 7 is so new, try the PW6 one, i sure it wont be far different)
  3. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Well it says that the pw7 excepts 50Hz and 60Hz but i can't still find how to change from 50 to 60?
    If anyone can let me know because i can't find it in the manuel.
    cheers
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    Hunts you don't change 50hz to 60hz. Off board processors and certain DVD players have this ability to get round compatiblity issues, but this conversion almost always introduces a degree of "judder" to the image and serves absolutely no benefit in terms of picture quality (unless you find the 60Hz refresh more acceptable despite the judder!). What the panel does do is actually convert 50Hz into 100Hz anyway! (60Hz signals remain at 60Hz).
    If you wanted to carry out more advanced tweaks of your screen you would need to invest in a dedicated video processor (search: Lumagen, Cinemateq, iScan, Crystalio) which would then take over deinterlacing and scaling duties from your screen, and other functionality including frame rate conversion. This ain't cheap though...
  5. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Liam thanks for the reply,i will stop searching now.
