Panasonic TH-42PW7 - The Basics!!
Discussion in 'Plasma TVs' started by Mario Basler, Jul 21, 2005.
  1. Mario Basler
    Mario Basler
    I'm a plasma virgin but have been reading reviews on the web site extensively for the past 3 days. Not sure if it's confused me even further but i think i've made my mind up on purchasing a Panasonic TH-42PW7 plasma screen as there seems to be a lot of love out there for this particular model.
    As i understand it, this is a plasma screen opposed to a plasma TV and needs a few add ons to get it up and running.
    I'm not wanting to connect much to the screen, only a standard DVD player and a Telewest cable box but unsure of whether i need a component board, composite board or a scart terminal board. I may be hooking this up with a surround sound system in the near future as well. I've also read something about getting a RGB converter but i seem to be a bit confused over how this works!!
    I was also wondering if this was good value for money at around £900-£1000 or should i look elsewhere?
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
  3. Dave
    Dave
    Jul 3, 2005
    11,483
    163
    +3,392
    Value for money is incredible with the PW7. You get a lot of screen for the money.
    I don't think there's anything else to touch it at current prices and because there are so many different ways to connect it up, upgrading your other gear in the future gives you more options.
  4. absthechatter
    absthechatter
    Nov 27, 2004
    159
    If you are not getting surround sound system for a while, you will also need to think how you are going to get sound. The panel does not come with speakers attached, although it does have built in amp so you can attach your own speakers if you have them.
    Abs
  5. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    If you're getting surround sound and an amp you could have just one cable to the plasma from the amp................ and connect the DVD and telewest box to the amp...........................and switch them through that.
    Cheers,Tam
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,966
    2
    4
    137
    Garstang, Lancs
    +1,565
    The RGB box basically splits the video and the audio from a RGB SCART (from your telewest box), the video goes to the VGA input on the plasma, and the audio to can put through your amp. This gives you better quaity picture than a SCART input.
    If your DVD has component out, you can get a component board for the panel and again, put your audio through your amp. This will give you the best picture from your DVD player.
    Here is a link for forum member discount prices for the PWD7 (basically the same but better than the PW7:
    http://www.avforums.com/forums/showthread.php?t=169453
    I think your budget needs to be a bit higher for this, maybe around £1400 but there is no better option for that sort of money.
