panasonic TH-42pw6b
Discussion in 'Panasonic TVs Forum' started by dali1020, Jun 29, 2004.
  1. dali1020
    dali1020
    Jun 26, 2004
    285
    Reading
    +3
    "Going for the panny th-42 pw6", new to this sort of system and would like some help from you guys please! I want to connect my kiss dp-400 dvd,pan tu-dsb30 sky box & my pan sa-xr45 av receiver, will i need to bye a scart board for the back of the plasma with all the connections on? ( whats the best opption) what cables do you think i will need? Is there a site i can download the manual from? cheers dali1020 :beer:
  2. betamac
    betamac
    You can go the cheap and acceptable way or the exspensive and best way
    I when the best way as i thought considering the price of the display it was worth it
    I used Component to VGA to hook up my AV Amp To Plasma VGA In
    I then connected my DVD Player to Component in On Amp
    I Then Connected Sky Via RGB To Component Box And Then Into Amp
    And Then Connected My Gamecube To Component Video Board On Plasma
    Component in the best way to connect your devices if they support it
    But A Scart Board on the plasma and A Scart switch box like the Quintro AV Sales Sell would connect everything to plasma just not quite look as good
