Panasonic TH-42PW6 screen jumping
Discussion in 'Panasonic TVs Forum' started by nickquest, Jan 20, 2004.
  1. nickquest
    nickquest
    I have a problem with my Panasonic TH-42PW6. When playing an RGB signal thru SCART into the tuner box, it causes the picture to jump slightly. It does it with Sky or DVD. Playing a DVD thru component signal (3 RCA) is fine, but my Sky+ box doesnt have component out, only SCART. When you have the Sky+ box set on PAL, the picture doesnt jump but the quality isnt as good. Could there be a fault with the tuner box, or is it something simple?
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Sounds like the panny is expecting RGB with sync on green and you are feeding it RGBS ( commonly found from a scart device) . No sync getting to the panny.
    You might be able to feed it sync to a composite input on the panny . Don't know for sure though.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You have the TU600 tuner? Unfortunately, it's a member of the not terribly good club. It could be a tuner fault, but it might well be 'standard' if it happens not to like your sky box. I believe the manual actually recommends PAL over RGB from stb's! You'd be better off without it.
