Panasonic TH-42PW4 info please ?
Discussion in 'Plasma TVs' started by Gliese 581c, Jul 6, 2003.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    7,836
    On AVForums
    +523
    I would like to gain access to the expert and service menu's on my plasma. I would like to know if the plasma is displaying prog scan etc and how many hours the set has been running for etc etc
    If anyone can help that would be appreciated.
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Originally posted by jmack
    1. Hold the volume button on the panel in while pressing the status button on the remote 3 times very fast (status button is the one under the power button).
    2. A menu appears highlight the icc menu and press select.
    It should say in the top right hand corner what signal is showing ie 525p 525i 625p 625i.
    You must have your panel on the component imput and your dvd player on at the time of doing this.
    To get out press the setup button then turn the panel off.
    Not sure if it works if you have a tuner connected though.
    Be careful in there dont go changing things.
