Panasonic TH-42PHD8 connectivity question?
Discussion in 'Plasma TVs' started by Degas, Oct 12, 2005.
  1. Degas
    Degas
    Aug 29, 2004
    191
    Ok, after reading for the last month or so I have decided against going for a Pioneer 436XDE or a Panny 42PV500, and decided to plump for the Panasonic TH-42PHD8, a great choice if I do say so myself. This leads me to a number of questions tho so please be patient.
    I currently have the following:-
    Sky+
    Pioneer DV-575A DVD player
    Technics Amp
    JVC Plasma
    Now I will be using new Denon 1906 amp and screen clearly, but I want to be able to connect the Sky box and DVD player obviously, I will also require the panel to be able to take an Xbox, a Gamecube and an Xbox 360 (I may wish to add a PC type input at some point too). I clearly will not be using the consoles at the same time so some unpluging of cables is fine. I will also be getting Sky Hi-Def and will want to connect the Xbox 360 via Hi-Def.
    I have seen the following item in a thread about this subject:-
    http://www.js-technology.com/produc...&products_id=36
    Would I require the above?
    Basically I want the best possible PQ I can get without spending silly money on a scaler (not that I'm sure what one does..... ) and having 1,000 cables.
    So any help with extra boards or whatever I will need would be really helpful, preferabbly from AV Sales cause I wanna order this stuff tommorow for delivery on Friday.
    Cheers chaps.
  2. ukdan
    ukdan
    Feb 16, 2005
    1,124
    swindon
    +84
    I have sky+ going to js rgb to component converter, then to amp.
    dvd575 via component to amp.
    Then from the amp to phd8 vga port with a component to vga lead.
    The phd8's vga port can be configured to accept component in the setup menu.
