panasonic TH-42pa30 or TH-50pv30
Discussion in 'Panasonic TVs Forum' started by pitpete, Aug 2, 2004.
  1. pitpete
    pitpete
    Dec 9, 2003
    12
    Is the brightness 500 (CD/m2) of the TH-50pv30 enough for good picture? TH-42pa30 has a brightness of 850 (CD/m2). Is the difference visible? Also there is HD-panel in TH-50PV30 does it make the picture better for watching DVD and TV compared with TH-42pa30? :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Where about are you? Size and price are normally more dominating factors than the brightness between these 2!
