Panasonic TH-42PA20
S
se7en
Just a quick question really, i notice that when i watch DVD's, my plasma sort of looks a bit pixelated, is this normal because it's quite noticable far back too. just delving into the world of plasmas so sorry if this is a bit of a silly question. Just the fact when i saw a plasma in a store it looks crystal clear.
hmm, while i sort out my configuration, i just bought a cheapo dvd player + 5.1, still would have thought it'd be fine...
DVD Player - Bush DVD AV11K and using a cambridge audio premium audio/visual interconnect scart connection atm, any more information needed ? New at this still so let me know :)
seems a bit of a false economy spending 3 grand on a plasma and feeding it with a cheapo DVD - my advice would be to upgrade or borrow someones DVD player - to see whether the pixelation issue improves. Have you tried turing down the contrast?
yeah, i just bought a cheapo dvd player till i sorted out what kit i was going to spend my money on, so, i just wanted something to play my dvd's until i sorted it all out.
have tried playing with the settings, making it darker does seem to help, but still see it. i'll see if i can get a decent picture of it. i'm getting sky digital on the 9th though, so that should show a better picture i presume
The bush player will probably do RGB, you'll need to enable that inthe player menu, and while you're at it select 16:9. I see about 20 setups a week, and most have not done this.
it does do RGB, i always play the movies in 16:9 anyway, so it's not that...
i have a picture that's sort of exagerated, but i'll post it anyway so you know what i mean.
Pic
think it could be the dvd player ? scart connection ?
It's not the movies you have to tell it's 16:9. it's the player. The picture is not really very informative, tho I have to say if I left a customer's plasma like that I'd be out of business in a week.... I can't tell what's wrong from that in short. When you say AV scart, is it fully wired? Or is it a scart to 3 phono lead plugged into an 3 phono-scart adapter at the plasma? If so there is your trouble, you would have only composite video. Cure is a big fat fully wired scart cable.
hmm, set the dvd player to 16:9, it was on 4:3, hmm, would that make much of a difference to quality then ? have to say it looks better now though. thanks for the replies :)
No, no difference to image apart from restoring the correct proportions to the folks on film, but what about the cable?
Must be the player then, borrow another to try. It might not be crap, it might be faulty. Almost any DVD player is watchable, the differences as you pay more get more and more subtle.
hmm, ok, i'll give it a try, i also just got someone say this;
'I remember when I was in Sound Advice \when plasmas first came out and they were showing flubber on this tv... it looked really pixelated, but then sometimes I see others that are sharp as crap... so I couldnt tell you. But it might be possible that some models do that.'
getting me worried now :p
Unless yours is faulty, it's not the plasma. It is capable of very smooth cinematic picture quality when fed a half decent signal
that's what i was hoping, can you suggest a dvd player/leads (i'm guessing component video is the better option?)
hope it isn't faulty though, everything i seem to get is faulty :(
Depends how much. You can get a 3 phono to 15 pin d-sub to connect component video, anything will be a step up from what you have, Have a look at Richer's bargains, maybe Cambridge? Pioneer? They won't have the lead, you need to got to Lektropaks or TMF for a reasonable one or a good one, in that order.
Isn't the 15 pin d-sub at the front on the pa-20?
Would straight component cables into the back be better?
I'm still awaiting delivery of mine, so I'm probably wrong.
Just out of interest Maw...
On a PA-20 would there be a lot of difference between connecting Sky+ through the RGB scart or going through a RGB to Component video converter and using the component input?
Is there any difference in quality?
Cheers D
I wouldn't expect to see any difference at all, could even be slightly worse, too many conversions, even if VIRTUALLY lossless.
Cheers...
I was wondering about that one...
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
