Panasonic TH.37PV500 and DVD-player that upscales to 720p
Discussion in 'Panasonic TVs Forum' started by ErikX, Jun 6, 2005.
  1. ErikX
    ErikX
    Sep 14, 2004
    84
    There are several DVD-players that upscales DVD-movies to 720p, for example this Samsung. Will such a player provide a significantly better picture quality on a PV500 screen? Anyone testet it?
    Regards,
    ErikX
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    so you think a £150 DVD player can scale better than a £2k plasma ????
  3. ErikX
    ErikX
    Sep 14, 2004
    84
    Hehe...what do I know? I'm a newbie! :hiya:
    So the PV500 upscales the picture automagically?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    it will scale evrything to native res, all fixed pixel devices do (it will also de-interlace any interlaced sources so prog scan DVD players are only benefit when the DVD player does it better than the display, but try finding a good DVD player with interlaced component output no Progscan and no HDMI!!!!! Arcam DV88+ Tosh SD900/9000 etc are well worth buying if you can find one for senseible money!
  5. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    Yes Horny is right, it's a fallacy to believe sub £250 DVD players with upscaling potential will do it better than your panel which is a progressive display device anyway.
    I'm lucky enough to have a SD9000/900/9500 which when simply fed into my panel YUVi style produce fantastic results.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    GIT :D :smashin:
  7. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    :D
    It's such a shame that Tosh have pulled out of the top flight DVD game. They made the best while they were at it.
    I can honestly say I have never seen a better picture from a simple non complicated DVD >Panel set up.
  8. ErikX
    ErikX
    Sep 14, 2004
    84
    "it will scale evrything to native res, all fixed pixel devices do (it will also de-interlace any interlaced sources so prog scan DVD players are only benefit when the DVD player does it better than the display"
    So I shouldn't even bother to use a component cable from the DV575a to the PV500? Or am I misunderstanding something here?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    no you should use component, but let the better equipment do the scaling, de-interlacing etc just because something can do something doesnt mean its the best thing for the job....
  10. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Will the HK DVD25 do a better job than the panny PV500 at progressive?
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    not sure but i would let the panny do it (easy to toggle between modes on DVD) but i would stick to interlaced output
  12. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I will give it a go when I get it and let you know the results.
