Panasonic TH-37PE30B Help
Discussion in 'Panasonic TVs Forum' started by Manti, Jul 26, 2004.
  1. Manti
    Manti
    Jul 12, 2004
    12
    +4
    I'm just about to buy a PANASONIC TH-37PE30B Plasma, but there still are a couple of questions that I have:
    1) is there a way to check the hours clocked on this Plasma?
    2) I've been reading something about how crucial the first 200 hours are in the performance of a Plasma. Where can I find a "1st 200hours settings guide" to this (or any other) Plasma?
    3) Wich version of Digital Video Essentials (DVE) is the right one to better calibrate a Plasma like the Panasonic TH37PE30B?
    finaly... :p
    4) Does this Panasonic model have a memory setting for each input?
    Thanks for your time,
    best regards
    Manti
    (Portugal)
  2. Manti
    Manti
    Jul 12, 2004
    12
    +4
    ...forgot to mention that the Panasonic TH-37PE30B Plasma is the new VIERA 37" :)
    cheers,
    Manti
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    1) Service menu be very very careful!
    2)Search here, basically low contrast and brightness
    3)PAL if you are in a PAL region.
    4)Not for each input interms of Pic settings but does hav 3? Pic settings which different levels can be applied to.
  4. Manti
    Manti
    Jul 12, 2004
    12
    +4
    Thanks so much for your help hornydragon :thumbsup:
    Regarding the "Service Menu" is it simple to access? And after accessing it, what should I do? :blush:
    Thanks in advance,
    Manti
  5. Orlando
    Orlando
    Feb 2, 2004
    158
    Essex
    +5
    I have this set and you can have a different picture setting for each source.
    Whatever you set up on one AV source will not effect another. i.e Cinema for DVD and Dynamic for Sky. You can then alter all the various contrast, colour, brightness and sharpness within these main headings. i.e Cinema, dynamic, normal and auto (uses a external sensor to set contrast for the room lighting)
    Hope this helps.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Orlando, Interesting nice idea from panny.
