Panasonic TH-37PE30 & TH37PW7B
Discussion in 'Panasonic TVs Forum' started by darktherapy, Oct 13, 2004.
  1. darktherapy
    darktherapy
    Is the Panasonic TH-37PE30 the same screen as the TH37PW7B, with digi tuner, etc. built in? I have compared the specs on the Panasonic web site, and they look the same. However, the TH37PW7B is specified as a new model.
    Thanks in advance for your help.
    Darren
  2. sl8ed
    sl8ed
    Quote from panasonic technical bod....
    'TH-42PW7' screen is the same as for the PE-30'
    I would assume that goes for the TH-37 too.
    Assuming the panasonic technical bod is right in the first place :laugh:
  3. kirakira
    kirakira
    You better pray they are wrong because PE-30 (and any other overseas Viera model) uses gen6 glass! :rolleyes:
