Panasonic TH-37PA50B
Discussion in 'Panasonic TVs Forum' started by GedF, May 19, 2005.
  1. GedF
    GedF
    First time poster so be gentle guys.
    I have seen on Sound & Vision on-line a TH-37PA50B for £1199. Apart from the absence of Freeview (which I can't receive in my neck of the wood nyway), is there anything else I need to be aware of. Is this the only difference with the PE50 model?
    Thanks for any assistance
  2. knobbs
    knobbs
    hi far as i know this is the euro model imported.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    tis a grey import and gets panny's pan euro warranty cover not the UK at home cover but other than that and lack of FV its the same................
  4. GedF
    GedF
    Thanks - will this preclude me from obtaining an extended warranty for this screen?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    shouldnt do but check with supplier before paying for warranty (ask TADL as they have one of the better and more cost effective warranties for PDP's)
