Panasonic / Technics discrete codes?
Discussion in 'Home Cinema Control & Remote Controls' started by IronMonkey, Aug 12, 2002.
  1. IronMonkey
    IronMonkey
    Does anybody have discrete codes for these models:
    Panasonic TX-24DX1 (especially aspect ratio and power on / off)
    Panasonic DVD-RV60 (especially power on / off)
    Technics SC-EH750 (especially aux switching and DSPs)
    Any codes would be really appreciated.
    Thanks.
  2. smallman28
    smallman28
    Have you tried www.remotecentral.com there are some codes for the equipment you describe but not many.
    You may find that a tv on/off discrete code works for several different models from the same manufactuer as well,the on/off discrete for my dvd player worked with both the DV505 I had and the DV444 I have now.
