Panasonic TC-15LT1
Discussion in 'Panasonic TVs Forum' started by leobley, Jun 16, 2004.
  1. leobley
    leobley
    This LCD works fine with an NTSC signal coming into it's antenna input.
    I'm trying to get it to work with with PAL sources (Sky+ modulated output or direct video output from a Humax freeview receiver) fed into the LCD's video input (composite / s-video).
    To start of simply, I tried connecting freeview receivers (Humax 8000T and a simple box) via the composite / SCART-composite output to the composite / s-video input on the LCD. The resulting image shows a channel banner, for instance, with 5 to 6 copies shifted up the screen, and the audio is choppy.
    Can someone provide a technical description of what I'm experiencing (e.g., jutter, incompatible vertical refersh rate, ???).
    Even better, does someone know a workaround or if the Panasonic TC-15LT1 LCD is inherently incompatible with PAL-originated sources?
    Thanks... Leo
