Panasonic TC-1485T codes req.
Discussion in 'Home Cinema Control & Remote Controls' started by Taz, Feb 22, 2002.
  1. Taz
    Taz
    Hi all,
    A tall order i know, but where can i find a pronto download for this aging portable TV?
    dont want to buy a new remote for such an old TV when I have a Pronto...so any help would be good
    Taz.:cool:
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    A quick question m8 - do you have one of those all in one remotes that you can enter codes into?
    You might want to get your hands on one and set it up for your TV and then learn the codes into the Pronto.
    I've had a look around RemoteCentral, but they don't seem to have the codes for this TV. Another thing you might try is using one of the other Panasonic TV commands that are on RC and see if any of them work (you never know).
    ** Just had a brain wave (forgive me - I'm working nights at the mo)
    If I get time over the weekend I'll use my all in one remote and copy the commands to a ccf file for you and we can see what ones work for your TV. I'll just do the power off/on until we get the right code for the remote and once we get it I'll copy the other commands into a ccf.
  3. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Okay m8. I've set up all the codes for both the Panasonic TV's and the Aiwa videos for my One For All remote.
    Attatched is a ccf file that has two devices.
    Each device contains the remote commands to test against your TV and VCR.
    The TV ones are the power off command. Switch your TV on and then press each button until it powers off. Try all buttons as you might find that more than one code works for your TV.
    The VCR ones are the play command, so have a tape loaded and press each button until the VCR starts to play. Again, try all buttons to see if any of the others work.
    If none of the commands work then I'm sorry, but you'll have to get them some other way.
    Let me know how you get on and I'll set up any commands you require once you have tested all the codes out.
  4. Taz
    Taz
    alanrob,
    what can i say but a BIG thanks for all your help and work on my post.
    I will be checking the codes you have given me later today.
    I will be in touch;)
    Thanks again
    Taz.:cool:
  5. Taz
    Taz
    alanrob,
    ok I have tested the tv and its working with 2 of the codes you gave me. 226 and 274.
    if its not a major hassle all I need for it are the following codes.
    sleep timer - 1 - 2 - 3 - 4 - 5 - vol - power
    thanks for your help
    Taz.:cool:
  6. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Hi Taz,
    I'm at work at the mo, but I'll try and get these set up for you tomorrow and I'll post them here.
    Not sure about the sleep timer as the all in one just does the basic functions of power, channels, volume and video commands (play stop etc..).
    I'll learn all the codes in for each number and you can try them all out until you find one that will do sleep timer.
    How did you get on with the video ones?
  7. Taz
    Taz
    Thanks Alan.
    Got the VCR sorted thanks.
    Taz.:cool:
  8. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Hi Taz,
    Well, here you go. This ccf contains all the codes that the remote has for both the codes that worked for you. Some of the keys on the 274 code didn't do anything so I haven't included them.
    Have fun and I hope it does the job for you.
  9. Taz
    Taz
    Alan,
    Thanks a lot mate all working (except timer)
    thanks so much for you time and help
    Taz.:cool:
  10. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Nae probs m8 ;)
