Panasonic T.V. service menu help
Discussion in 'General TV Discussions Forum' started by Roy, Apr 12, 2001.
Tags:
  1. Roy
    Roy
    I bought a Panasonic TX33AK10 T.V. Does anybody know how to access the service menu,thanks.
  2. motta_lunn
    motta_lunn
    Jan 16, 2001
    40
    Hello.
    I have the TX-29AK1 model and this is how to get into the service menu:
    Bass to max.
    Treble to min.
    Hold down "index"
    Press "-" (minus) on the front of the set.
    This works on the PK1 series as well and will work on your TX-33AK10.
    My uncle bought the same tv as yours. How are you finding it? Where did you purchase it from and how much? Is there anything wrong with it due to the service menu code needed?
  3. music_m
    music_m
    how can i exit service menu ?
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,026
    Galactica C.I.C.
    +315
    exiting service menu can be done by turning the tv off an dthen back on again, or you should be able to do it if your remote has an exit button on it.
    Be very carefull mesing around with service settings. If you dont know what you are doing you can cause a reall mess in there :eek:
    Right everything down first so if you make any mistakes you can go back to the original settings. :)
  5. music_m
    music_m
    can somebody learn me options on this tv plz
  6. music_m
    music_m
    what's h-pos v-pos and other options plz help
  7. Ysl
    Ysl
    Nov 24, 2004
    38
    horizontal & vertical picture position
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,026
    Galactica C.I.C.
    +315
    What exactly are you trying to do in the service menu.? what are you trying to adjust/fix?
  9. music_m
    music_m
    srry i'm not good in english . the picture is not in center , i want to change position
  10. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,026
    Galactica C.I.C.
    +315
    Ok,
    you can do this by just looking at the screen, but i would recomend the use of a test pattern. These can be found on the Digital Video esentials DVD or the Avai DVD.
    To center the picture you will need to use the H-pos and V-pos options in the sevice menu.
    If you need to adjust any overscan you will need to use the H-amp and V-amp options in conjuction with the H-pos and V-pos options.
  11. music_m
    music_m
    what key's i need use to change h and v position
    tnx 4 help
  12. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,026
    Galactica C.I.C.
    +315
    There are normaly 4 coloured buttons on the panasonic remote controll.
    The first 2, RED and GREEN will cycle backwards and forwards through the options. The second 2 YELLOW and BLUE will change the values up and down. Then Press enter to store the values.
    Write everything down first before you change the values. That way if you make a mistake you can go back to the factory settings.
    Always be care full whenever you are messing around with the service menu of any TV set of plasma. If you dont know what you are doing , you can really mess things up!! :eek:
  13. music_m
    music_m
    tnx for ur favor . can u tell me what's the other options ?
    all options
