Quantcast
panasonic ST30 owner with a tape measure needed...
GoNz0
as i have a center speaker at 15cm high would one of you with a tape measure close by mine measuring the height from the deck to the panel please?
may be taking the plunge in the morning to replace my poorly 42LG7000 set & need to know if it will sit ok :)
GoNz0
its to 50" i am after due to the current sale price, i take it thats to the bottom of the set and not the panel itself ?
need to see how much i have to pack the stand to clear the center speaker if i can trouble you to measure again plz ?
Wootball
Just measured my 50" ST30.
To the bottom if the set itself is approx 35mm give or take. To the actual visible panel/screen it's approximately 112mm.
GoNz0
50mm stand needed then, thanks for that.. wont tell the wife until after the purchase ;)
Similar threads
