drivershigh
I have a Panasonic TV and Soundbar (SC-HTB690) that until recently have worked fine together.
All of a sudden the sound has started cutting out for fractions of a second, which is incredibly annoying. There doesn't seem to be any pattern to this, it can be 5-10 minutes without any disruption, then it will cut in/out a few times in 10 seconds or so.
It's the same regardless of the source (apps, switch, virgin TV box) and how the audio is connected (it was always through the Arc out, but it does it on the optical connection as well).
Is it just dead or is there something I'm missing?
