Panasonic software update problem - pls help!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by hartside2, Jan 5, 2004.
  1. hartside2
    hartside2
    I got a Panasonic TU-DSB31 digibox off e-bay and it arrived this morning (see my other post on http://www.avforums.com/forums/showthread.php?s=&threadid=109312 ). Seller said the software revision was on 2.8b, but if the system could be upgraded to 3.15 then it was a cheap digibox.
    I connected it up tonight and went through the routine for updating the software. The message appeared on the screen that the software was being updated. However after restarting the box the software revision number is unchanged and stays at rev 2.8b! I've done this a further twice with the same result
    Maybe I'm being suspicious, but could it be that it has been disabled from recieving a software update? I've attached a photo of what looks to me like a "cut" jumper.
    Anyone help out by confiming this or has anyone some other suggestions to make the box upgrade its software?
  2. sapo
    sapo
    Don't know about a jumper. This problem seems to pop-up very often. Panasonic charge about £60 to fix it.
    I wonder if you have discovered something.
  3. hartside2
    hartside2
    Anyone else help?
