panasonic sky digibox
Discussion in 'Sky Digital TV Forum' started by deanz, Aug 17, 2003.
  1. deanz
    deanz
    i had my panasonic dsb30 sky digital reciever for about 3 & half years now.I'm starting to get signs of pixellation,Football is the worst for it.........Time for a New one perhaps or is there something i can do myself?
  2. Fernsehman
    Fernsehman
    Check signal quality on the affected bouquets by entering the parameters in the Manual Tuning menu. If signal quality is low then you probably have a dish/LNB alignment problem, tree leaves blocking the signal, or faulty cable or connections.
    You could also test your Digibox on a friend's good dish system.
    Fman
  3. deanz
    deanz
    thanks for reply but what the hell does this mean?
    im not exactly a newbie but i dont know quite what you mean
    dean
  4. Fernsehman
    Fernsehman
    OK, read through the following technical page. It shows screen shots basically of what I'm referring to. The only difference is that it refers to an ITV bouquet. If that's not one that's affected, you'll have to look up the parameters for the ones that are.
    http://www.satcure.com/tech/page10.htm
    Hope that helps.
  5. deanz
    deanz
    thanks it has helped a lot
  6. joshua_bond
    joshua_bond
    Jun 25, 2002
    342
    +16
    what the weather like when u get pixellation?
