Panasonic set up
Discussion in 'Home Cinema Buying & Building' started by hit46, Jun 2, 2004.
  1. hit46
    hit46
    Grateful for advice on impending purchase (all online so no dealer support !):
    Panasonic 42" plasma TH-42 PW6
    Panasonic home cinema SCHT900 (SCHT870 ?)
    Sky box (e.g. Panasonic !)
    How to get a decent set up to connect it all up.
    42" plasma has a wide range of boards (which type is best to use ?)
    Home Cinema has one SCART terminal + the usual inputs/outputs
    Sky box will probably have two scart terminals
    ? Which are the best boards / connections / leads to use and should I connect sky-home cinema-plasma or home cinema-sky-plasma or doesn't it matter.
    Also would like to hook up my PS2 if possible....
  2. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    from dvd to plasma id be looking at component myself as anything less IMO isnt good enough. also plasma wise id get a progressive scan dvd player to match the Plasma.the jamo DVR 50 offer's alot and looks very very good on a plasma :) i dont know anything about that AIO u mentioned but thats all the advice i can offer.
