Graham / Phillip. Thanks for your suggestions. I've run mediainfo on both the original clip and one that PD10 produced, copied below. The original clip from the Pana camcorder is 1920 X 1080 interlaced. The produced clip is 1920 X 1080 MBAFF which I see from other posts could be because it is a panning shot. Whether it is i or p I don't know! I've produced another in 1080p and it looks the same.
I've also tried it at 720p and it might be a bit better, but not as good as the original. The Trial version of PD10 doesn't seem to let me specify 1080i as output. Maybe the full version does.
I intended to watch my edited images on a 26inch Panasonic which is 2 years old. I was hoping to do this via my HUMAX Foxsat using a USB or an external disc. (Except the output from PD10 was rejected by AV2HDR as “no NAL SEI frames in H264 source video”
Alternatively and more likely as my amplifier has just died I am considering (after comments seen on this forum) a home cinema system with a Blue Ray player that takes input from an external device. I like the look of the panasonic SCBTT270EBK but am not sure that will take the files. Alternatively the LG HB44S 2.1 as I don't really need the rear speakers. Any advice appreciated!
From other comments on the forum I think I need to update my card drivers anyway. Power Director seemed like a good package – I tried Sony Vegas platinum 11(trial) but found it difficult although relooking at the output it had none of the issues I have here – it dealt with swirling dervishes in poor light perfectly..
Mark
Original clip
ID/String : 1 (0x1)
CompleteName : C:\Users\Mark non admin\Desktop\00003.m2ts
Format : BDAV
Format/Info : Blu-ray Video
FileSize/String : 16.3 MiB
Duration/String : 13s 883ms
OverallBitRate_Mode/String : Variable
OverallBitRate/String : 9 858 Kbps
OverallBitRate_Maximum/String : 18.0 Mbps
Video
ID/String : 4113 (0x1011)
MenuID/String : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format_Profile :
[email protected]
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frames
Format_Settings_GOP : M=3, N=12
CodecID : 27
Duration/String : 13s 840ms
BitRate/String : 9 075 Kbps
BitRate_Maximum/String : 16.8 Mbps
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate/String : 25.000 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Interlaced
ScanOrder/String : Top Field First
Bits-(Pixel*Frame) : 0.175
StreamSize/String : 15.0 MiB (92%)
Audio
ID/String : 4352 (0x1100)
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
CodecID : 129
Duration/String : 13s 952ms
BitRate_Mode/String : Constant
BitRate/String : 384 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bits
Compression_Mode/String : Lossy
Video_Delay/String : -80ms
StreamSize/String : 654 KiB (4%)
Produced clip
Complete name : C:\Users\Mark non admin\Desktop\Produce_3.m2ts
Format : MPEG-TS
File size : 9.63 MiB
Duration : 4s 602ms
Overall bit rate : 17.6 Mbps
Maximum Overall bit rate : 40.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile :
[email protected]
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=13
Codec ID : 27
Duration : 4s 240ms
Bit rate : 16.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.317
Stream size : 8.30 MiB (86%)
Color primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM
Transfer characteristics : BT.470-6 System B, BT.470-6 System G
Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601
Audio
Menu ID : 1 (0x1)
Format : AC-3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 4s 224ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 9ms
Stream size : 132 KiB (1%)
