Panasonic SD60 Camcorder: Couple of quick basic questions!
Paul MC007
Hi all
Just a couple of really basic questions that I hope someone might be kind enough to answer for me:
Thinking of getting the Panasonic SD60 Hi-Def Camcorder - it seems to get really good reviews at a fairly decent price.
Now, only having ever owned SD mini-dv models in the past leaves me a little blind to memory card camcorders and HD.
So my questions are:
1) How much hi-def (at top rate) can you record onto various memory cards - say 16gb for example? Whatever the answer to this is, would you just double this for a 32gb?
2) Whilst I have a HD-TV I don't have any way of storing the HD material, other than keeping the memory cards and keep buying new ones (I presume this is the only way of keeping HD stuff if you don't want to go down the pc route etc)? Therefore, is it easy (and possible?) to plug the camcorder into the front of my DVD recorder (which is a fairly modern Panasonic XW380 - can record freeview HD on to the internal HDD but not to disc) and make a SD down converted copy of any HD stuff that I shoot?
Many thanks in advance for any help!
senu
Hi all
Its best to get an SD60 manual and check Ive seen it linked somewhere unless a user here can tell you but yes a double sized card should take double the data
No you can and should store the files on HDD, whether on a PC or not and even if you dont want to go down the PC route , you may have no choice .. just to stor the footage onto Ext HDD
Cards are not as cheap as MiniDv tapes and are meant to be reused
Yes but it that easy ( as SD via composite analogue :rolleyes:) .. unless you want to keep that HD footage on cards :cool:
What is possible is to buy a media player like WDTV LIVE and play the HD clips to your HDTV through it from USB storage .. Even small Ext HDD
Paul MC007
Thanks for your response.....
I've got an external HDD 250gb, so presumably I could download the footage to this...how would I get this to play through my tv though (if I had the footage on the external HDD) - it's an iomega 250gb external USB connecting HDD. My television is a Panasonic V20 Plasma - it does have USB sockets, so is it likely to recognise the footage on this straight away if I plugged it in to the tv (the HDD external drive that is?)
Thanks for any help again - really appreciated
